The temperature correction calculator link has been removed...
For some reason the long time temperature correction calculator page offered by Copper Alembics has been removed, or is down for some reason. CA has been contacted to urge them to repost this page and useful calculator. Fortunately - and once again - the wonderful guys and gals at the long established Homedistiller.org have provided what is actually a better resource:
http://homedistiller.org/index.php?mn=c ... 8&tempi=20
Please note that you have a choice of which formula to use. Most of the hydro's we use are calibrated to 20 deg C (68 deg F), so use the method "Formula (20 °C)". If for any reason you have one of the very few hydro's calibrated to 60 deg F (which I doubt) you can used the method "Formula (60 °F)"
Thanks to Schlimmerdurst for his PM regarding the close down of the old CA calculator page. To the good, because the Homedistiller's calculator is much more comprehensive.
Thanks again S....
Important! Sugar test temperature correction change!
