Size Counts: Pipe Capacity
Posted: Fri Jun 06, 2014 5:25 pm
A handy reference... in cubic inches
Like many others the "grading" of pipe, eg by Dunhill, is hard to understand, because the grade does not truly correlate with the volume of the chamber. Seems most pipe's bowl chambers are typically between 0.6 and 1 inch in diameter (with 0.75 common), but to various depths. Ergo, they are hard to compare.
Found this chart somewhere. Whether it helps or not...
Posted: Sat Jun 07, 2014 2:52 pm
by Dai
I've noticed that myself not many sites tell you the depth of the chamber.
Posted: Sat Jun 07, 2014 4:13 pm
I wouldn't buy a pipe without knowing it's dimensions. Most sites I go to do but on the odd occasion that I find one that doesn't an ebay check or google normally works.
