Capn Jimbo's Rum Project Forum Rum Appreciation by and for the Compleat Idiot
| View previous topic :: View next topic |
| Author |
Message |
Capn Jimbo Rum Evangelisti and Compleat Idiot
Joined: 11 Dec 2006 Posts: 1413 Location: Paradise: Fort Lauderdale of course...
Posted: Sun Dec 19, 2010 9:09 am Post subject: Dilution Formula/Tasting: adding water to Overproofs |
When tasting, should you add water to overproofs?
In short, no. Or yes.
In tasting spirits, particularly single malts (but also some rums) occasionally you will run across some real overproofs. This creates the problem of "alcohol shock" and the inability to "get" all the aromas and flavors inherent in your dram.
Still, it's our policy to taste a spirit just the way it comes out of the bottle, particularly if the spirit is only slightly overproof, say 85 or 90 proof. Still there are some rums like Wray & Nephews Overproof (120) or Smith & Cross Jamaican Rum (114).
These two can be a shock to the system and really do require a bit of water.
Our solution with W&N and S&C was to take careful, tiny and uncritical sips - you need to get over the early shock, and this may take a few sips. We then started dripping some water into our glasses, swirling to mix and then renoting the effects. You'd be surprised just how much water is appropriate.
Now there are some skilled whisky tasters that swear that it's important to taste all spirits at 40% (80 proof) for fair comparisons. To make this easier here's a formula to calculate how much water to add:
Amount: for 1 oz.
(Proof x 29.6) / 80 - 29.6 = milliliters to add
For a half ounce, of course, merely halve this amount.
In sum, start neat at full strength, then add literally a few drops (even this tiny amount will reveal many aromas). To add larger amounts of water I suggest buying a 3 milliliter (3cc) syringe.
Purists use distilled water, Compleat Idiots use tap water, Preachers simply convert wine to water... _________________
| Back to top |
Posted: Sat Jan 14, 2012 5:27 am Post subject: Still confused? I am... |
After rereading the above blather some months later, I realized just what a Compleat Idiot I can be. Like any of us are gonna write the fuckin formula on a shred of paper and carry it around in the zipper pocket of our wallets (or purse in the case of the Preacher). I thought there must be an easier way.
And there was.
After agonizing minutes of deep concentration, and with the able assistance of my handy dandy conversion program, here it is...
| Quote: |
1. An ounce of booze is 6 teaspoons.
2. For every ten proof over 80 proof, add 3/4 teaspoon of water (to bring it down to 80 proof (but not all at once). |
But don't add this all at once! Here's why:
1. You're not making a mixed drink here, and the primary objective is NOT to dilute the overproof spirit.
2. The primary objective IS to release flavors and to find the "sweet spot" insofar as evaluating (and enjoying) the spirit. A few drops may well do this.
This is why I suggest you obtain a 3 or 5 milliliter (3-5cc) syringe (purchased at the drugstore, unless you're a nurse or MD - then just steal one). For a 90 proof, draw up 3.7 ml of water, then add say one milliliter at a time.
Come to think of it, why not just buy a one milliliter/cc syringe. Yeah, that's it!
Capn's Special Note: If you've ever watched Ralfy - who often drinks barrel proof whiskies in the 90 proof range - after an initial tasting, just tosses in a teaspoon of water and has at it. Other qualified tasters really do start adding water in drops. _________________
Go to Save Caribbean Rum Petition! |
| Back to top |
da'rum Admiral
Posted: Sun Sep 09, 2012 8:00 am Post subject: |
I put this in Smith and Cross review but may help for it to be here as well.
http://homedistiller.org/calcs/dilute
Equation is
Multiply the amount of spirits you have by (strong/weak) - 1
EG; 30ml x ((57/43)-1)= 9.767 or rounded up to nearest whole = 10 ml _________________ in goes your eye out |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
